Dehning
I intended to take my Busa to watch the Texas mile and when I took off, I noticed a slight hesitation and hoped it would clear itself. After a few miles it didn't so I turned round and switched to another vehicle. Bike still pulled strongly mind you.
After I cleaned the fuel injectors, disconnected the PC3 & TRE, testing the harness I was at a loss. I realized that when I pull the wiring connector off the right most fuel injector that the problem didn't change even if I swapped fuel injectors so I realized it was something to do with that cylinder. Finally in desperation I swapped the spark plug with a used one I just pulled out of my GT250R . . . problem solved.
Ran down to local auto parts store and $30/4 NGK Iridium plugs later, she's purring smoothly again.
Just goes to show you, it can be the simplest things
