jeremy_283
I cannot find any info on how to install them or what I need or anything? I am just seeing stuff for Gen II's..... can someone help?
Russell I didn't take my nose off.
Do you have to remove nose on a GenI ?
If so why ?
where you get them? whats the total price?
Ive installed over 200 kits and never taken a nose off!
Wow look what the cat dragged in!
laughin, yea im trying to get my 7th kanji like you have master poster!
+1 on the DDM kits. I have DDMs in both my CBR1100xx (55w 5000K) & my VFR800 (2 x 35w 5000K HiLo), the busa came with some other brand.
I kept the incandescent bulb in the Hi-beam because the HID's take time to warm up and when I flip on high beams, I want light immediately.
Think about wiring in a simple DEI 528 T delay timer to delay starting your HIDs till the bike is running (mine is set for ~15 seconds). They are dirt cheap, easy to install and will extend the life of your ballasts.
After installing quite a few of these kits now, I too am intruiged by how you do it without pulling the nose off. I think the time to remove 2 mirrors and 16 screws would more than make up for the frustration of trying to do a decent job in the cramped nose section still on the bike.
Now as far as functionality goes, THEY ROCK!
yes the nose has to be removed, it makes it so much easier. the bulbs are h7 and 9005. i mounted my ballasts on the air tube with the double sided tape and used zip ties for all the wiring. its pretty easy to do. the hardest part is getting the nose on and off.
