Gsxr 750 help
tray
I know this is a busa forum but I need your help. A friend of mine 2007 750 it over heated and for some strange reason when you put it in gear now it doesn't move. But it shift into all gears. The odd problem is it will also roll back in forth will it is in gear. Look for any possible place to start look being that his funds are limited. I offered to take a look at it grant I can work on a busa this is one.
Thank good help turn them over and it's running smooth... Nothing like a busa but it's running.
sounds like a simple fix...thanks goodness for the knowledgeable members of the org!
