LeDauz
Was reading up on EPA new cure for renewable resources that goes into your tank and found E15(Ethonal 15% blend).
What is E15?
Ethanol is an alcohol that can be mixed with gasoline to result in a cleaner-burning fuel. The most common blend of gasoline and ethanol is E10, or 10 percent of ethanol to 90 percent of gasoline. E15 is gasoline containing 15 vol% ethanol.
The primary source of ethanol is corn, but other grains or biomass sources may be used such as sorghum, corn cobs, cornstalks, and switchgrass.
E15 (a blend of gasoline and ethanol) | Fuels & Fuel Additives | US EPA
My thoughts on this is simple why? why? First off E15 will be slightly cheaper then fuel without ethonal,But will lose MPG
is it worth using renewable resources that give off less polution per volume but requires you to use more of it to perform the same task?
How many people already don't know whats the difference between E10 and gasoline?
How many New motorcyclists will accidently put this in their bike and be out hundreds of dollars?
What is E15?
What Vehicles and Engines May Not Use E15?
All motorcycles.
All vehicles with heavy-duty engines, such as school buses, transit buses, and delivery trucks.
All off-road vehicles, such as boats and snowmobiles.
All engines in off-road equipment, such as lawnmowers and chain saws.
All MY2000 and older cars, light-duty trucks, and SUVs.
All 2001-2006 cars, light-duty trucks, and medium-duty passenger vehicles (pending a waiver decision with respect to those vehicles).
