MeltDownZ
I've been doing the chain cleaning with Kerosene as recommended. Works great in a pump-spray bottle. I'd like to go ahead and clean the swing-arm, etc. with it.
Will Kerosene hurt:
- the brake pads?
- or bearings?
- plastics?
- tires?
- anything else?
And what do you clean the carbin fiber mufflerz with? What can you add for a shine/protection after they're clean?
Thanks!
<!--EDIT|MeltDownZ
Reason for Edit: "None your bidnezz"|1093447573 -->
Will Kerosene hurt:
- the brake pads?
- or bearings?
- plastics?
- tires?
- anything else?
Thanks!
<!--EDIT|MeltDownZ
