BigBadDodge
I should be able to start the bike in gear with the clutch pulled in correct? Didnt realize i couldnt till this morning, long story short a buddy was arguing the bike should still run in gear when the kickstand is down and his buddies bike was "stalling" and wanted me to look at it, proved it with my busa then this morning it wouldnt start, thought the battery was dead and for lack of time just took the cbr to work. Got to thinking i never put it back in neutral.
Had the same issue with the honda and it needed the little switch up by the clutch lever and problem solved can be started in any gear with the clutch in.
Is the busa the same way?
