jeremy_283
I was torquing down some crankcase bolts tonight (2 of them) and I think i accidently torqued them to 20ft.lbs instead of the 19 specified.... I got worried that something bad may result but then I thought about it... I've been using a Kobalt clicker-type torque wrench for 3 years very extensively (i use on everything, have a habit of stripping out bolts) and never had it re-calibrated... you think its pretty far off or what?
also, any harm in the crankcase bolts being 1ft.lb overtorqued? its the ones that holed the pair valve bracket to the crankcase...
