Pat Dietrich
Ill post picture when I can but #3 is really black. Took throttle bodies off and also around #3 throttle body where it goes into boot on head it is covered with oil as is the vacume line that eventually goes to airbox. Just right there at the #3 spot. Now I checked valves and they are ok. Maybe a hair on the tighter side on IN ( .004) but they are all the same. But what I did notice is that on this particular cylinder, the clamps that hold the boot to Throttle body when squeezed shut with fingers is still really loose. They all have these little spacers inbetween the clamp so tht it cant be squeezed completely together. None of the others are loose like this when I did the same thing so wondering if it was not sealed good what would my symptoms be. It idled fine but my hp is actually down by 6hp from last time I dynoed so I know whatever is going on with #3 is causing a hp loss. It is extremely rich. This is a 1441 with cp 13.25cr pistons with headwork and 385 megacycles tuned by Ryan Schnitz.Any ideas would be appreciated as always. I need all my cylinders for some 8.60slease:
