Seafoam can go in oil, air(vacuum), Intake and gas. Forget exactly if it says to,but you do it before you change you oil and run it a few miles. Then change the oil. Goes in oil for same purposes as anywhere else. Cleans things up.
didnt someone on the site say to turn the bike off and use a spray bottle to spray the seafoam inside the intake manaifold with the throttle pulled back all the way? Im afraif to do this vaccuum line thing... idk why... maybe cause i just have never done it
