Dang Reflectors
Busa_Powered
Picked up an 06 Busa a few weeks ago.
Got the rear reflectors off, having a fit with the front ones.
I have the socket wrench out, and I'm having no luck.
What size socket should I be using?
I'm turning it left, toward the rear of the bike and it holds, then it slips.
Its really irritating me.
1.Either Im not strong enough :banghead:
2.Turning it the wrong direction (Im going lefty loosey)
3 Or Im using the wrong socket, Im using the 12mm
I dont think its spinning
Maybe I dont have enough strength, I think I do.
I pull the socket wrench to the left, to loosen, and i pull and pull, it eventually slips off the bolt.
Really irritating me!
Make sure you don't strip the bolt. That would just make it even more of a pita. If it is being tough on you, you can always try and use something like a bar over the wrench handle to give you some leverage. And make sure the socket is sitting over the bolt nice and flat and not at an angle.
