moloko
Banned
I want to remove the entire housing so I can cut out the box underneath of it that holds the plate light. Is there more than just the one screw in the center holding it in? Obviously because mine won't come out.
I find it incredibly short sighted that they would require you to remove the entire tail section to get this off.. so I drilled a hole in the plastic (trunk area) behind that center screw to get it out.
What else is holding this in?
Did multiple searches, couldn't find anything.
