Gearing
rdnckjim
Bike seems a little weak sometimes, already did a thr bod sync and only thing left is to get valves shimmed, but I dont know they are even out. Wondering if I should drop the front sprocket a tooth or two. Any input would get great
go up two in the rear great all around gearing. You get a better pull on the bottom but still good top end.
I'm from Chesterton, IN bout 2 1/2 hrs north of ya, so I should go to a 42 rear, I though that the front gear controlled most torque in sprockets, but then again I am still kinda new to this
They are a little weak stock, they're geared too tall for high speed from the factory. They should have geared them a little lower. I run the 16/42 gearing on mine.....I think its perfect :beerchug:
