Zoinks!
So I got tired of having a bunch of wires all spliced together and having a bunch of clutter and jumbled up wires at the battery, so I got a fuse/ground panel from ebay and installed it on the bike. Now all I have is one extra wire on each battery terminal and an easily accessible fuse panel for all my current and future accessories! I really like having the grounding block combined with the fuse panel cause it keeps me from having to search for a good grounding point for whatever I'm installing. The power and ground are right there at the same place.
This was the first time I'd taken the tail off and after all the threads I've seen on here about people forgetting to hook the cable back up to the hump release, the last picture is my solution to that problem. Some of you may want to consider it next time you remove the tail.
