Finally gonna be enLIGHTened & get a PULL on things
redkat05
Dear spring....... HURRY!
Gonna get the hi/lo kit from DDM & get a set of Pazzo levers(copies) Saturday! Pretty pumped.
Need any help on the DDM tuning stuff give Blanca or I a call! :poke::laugh: The levers are easy peasy!
You'll be fine with it RedKat - the HID's are 2 connections, the positive and negative leads from the stock harness. It'll be a walk in the park with your past LED experience. The levers are a single bolt, out then back in through the new lever and don't forget the insert that comes out of the stock lever - like they said...very easy. :thumbsup:
