hey .org, just went on a ride and stopped for a drink and some fuel. got all that done, hopped back on and it turned over about half a turn then nothing. did that a couple times after letting it set for a min. got a jump. when it started, right when it hooked up, FI light came on. rode home ran fine, left it running to pull FI code, started idling really rough then died.
now it acts like it doesn't have enough power to fire the dash.
it cranked fine this morning and every time before. i had this happen one time before just the not starting but it was about a year ago when i first got it.
is there anything i should check before i just go get a new battery and try it. i tested voltage at battery and it was about 7.5. so i know that's not good, but if the charging system was bad, wouldnt it have ran bad on the way home?
my mods are bazzaz zfi+qs, afm, and thats about it electronically, no hids or any other add ons.
any help is appreciated and thanks in advance
matt
matt
