hi everyone *new* I purchased my busa -05- ( stock ) on -09 at the begining of the winter,it look and sound like factory, 12 k. on it. I start to use it know cos is geting warmer. but if you live in NYC sometime you will get stock in traffic,and I noted it was overheating.after reserch and all kind of test like change of coolant,bleed D air, removed the thermostat, put e togle switch to the temp.sensor , change nombers of blades, nothing work.but only get hot when am stock in traffic or idle.so common sense is telling my, >is not geting good air< so I went to D web. got my e -08 busa fan, installed and no more problema, no mater how long on idle or hot the wether is... no wonder this suzuki people start ading 2 fan 2 the busa. by the way that sound like a *RECALL* 2 my.
