Just bought her a month ago from a private seller... 04 limited Busa. Aftermarket is Yoshi RS3 slips, PCIII, new OEM plugs, 11.5k miles. It started smoking today omw to work. I got there and noticed a lovely oil spot on the pavement. I dont know how to describe the heartbreak Im feelin atm. I took off the right fairing and discovered a mess in there. I assume the whirlwind affect inside the fairing threw the oil all around. I think I narrowed the leak to this thingy (see pics). I also noticed a rattlingish noise when driving. Its faint but sounds like a rumble. I also get blue smoke out the pipes. I had the a tech that I know check it out. Its some oil line that needs it crush washers replaced. Its wierd tho, It just started today. I havent taken this thing past 6,000 RPM's (Still squeemish on it) so I am at a TOTAL loss.
One thing the tech said would cause the blue smoke all of a sudden was the amount of fuel injector cleaner I put in it. I kinda sorta put the whole bottle in it... Ya ya, I know, I wasnt thinking. But, Any advise would be helpful. I live in the DFW area of Texas.
