The one I have has four allenhead bolts on each end .Unscrew those and the baffel comes apart ,Thats how I have rerpacked mine,It's a straight through pipe with baffel materal wraped around the inner pipe
thanks guys...my can does not have rivets or bolt holes..so i guess i will try and figure it out myself..want the exhaust to really rumble..too weak for me..if this dont work ..i will get the muzzy
there is two rivets at the end of the can near the exhaust hole...is that where i need to drill to remove the baffle? there is only 2 rivets and it looks as if it is holding the micron "M" emblem together on the end
