Wow! What a new idea for a bike stand...
Okay, anyone remember talking about the Bursig stand? Well screw that, THIS is the ultimate stand hahahahahahaha..this thing is nuts!
War Eagle Superbike Stand
This Newly Patented Sportbike Lift is the first of it's kind in the world and will take over the bike stand industry! No more hassle removing wheels, engine, forks, etc....
There is no place that you cannot reach or work on. You are able to lift a sportbike around 6 feet up and turn it up or down 90 degrees.
The Motorcycle is only attached with a center piece and a rod connected to your swingarm spool.
Specs:
Holds any size Sportbike
Work on any part of the bike
Available in Red only
All lifts are Powder Coated
Lifts nose up 90 degrees
Lifts tail up 90 degrees
Perfect for all workshops
Perfect for all Racers
Item no. 57869
Retail: $2,299.00 (PLUS shipping)
You can mount your superbike on this stand like a normal stand, but you can turn you motorcycle so that the front of the wheel is looking up to the sky or turn it around so that the back wheel is looking up, you can lift the motorcycle almost 1.5meters up!
Specs:
Item no. 57869
