s1000RR does 8.49 @ 156
Mr. Anderson
exhaust, extended, PC-V....sick!!!!
- BMW S1000RR Ryan 8 49 158MPH MOV[/url]
Airshifter too, were those stock wheels?
No, BST's. Here's the specs:
2010 BMW S 1000 RR
Engine: Stock (203 RWHP/80 ft-lbs SAE Scale using VP MRX01 Fuel)
Exhaust System: Brock’s Performance Full Titanium CT-FM™ Carbo...n Tip Megaphone with Anodized Flames
Fuel Injection Control: Dynojet PCV with Brock’s Performance Custom Map to match the CT-FM.
Wheels: BST Carbon Fiber
Tires: Michelin 120/60 Power Pure Front - 190/50 Power One Rear
Bearings: Worldwide Bearings Ceramic
Swingarm: Brock’s Performance 9†over Alumi-Pro™ by McIntosh
Shock: Brock’s Performance Dragshock™ by Öhlins (Dual Stage Compression with Remote)
Sprockets: Vortex (17-47 to start)
Chain: Regina 530 ZRP 160 Link (O-Rings removed by hand)
Clutch Modifications: Brock’s Performance Clutch Mod, Cushion, Springs with Adjustable Spring Tops and Shims
Lowering Links: Brock’s Performance Window Links
Front End: Brock’s Performance Radial Mount Front End Lowering Kit (Radial Mounts, Strap End Kit, Strap)
Oil: Alisyn <<0 Weight
Oil Additive: Petron Plus
Coolant: MoCool by Motul
Mirror Block Offs: Brock’s Performance
Brake Line-Rear 9†over: Spiegler Performance
Brake Pads: Carbone Lorraine (SBK5 Compound)
Seat: Custom Cover by Bob Kussman of Dayton, OH
Special Thanks:
Scott Robertson
Sonny Kerschner
Terry McIntosh
We will be testing the bike as above on Friday and then changing the configuration for the rest of the weekend.
Watch for updates on Facebook!
Brock
Brock's Performance Products
