mike04busa
Just wondering if the people using TL peg's are using the screw in feeler's from the stock peg's in them or are they too long. Or what one's to use.
Funny i just searched alot about these pegs all morning. Got the PN if anyone need em. best price I found is about $56 plus shipping Only question I had was are the shifter and brake effected? I had the Buell pegs on for about 1 ride then chucked them. I could not stand the shifter position in relation to the peg. They seemed to have a wider stance making it so you can only shift with your big toe.
Oh PN are 43510-02F11 and 43520-02F11 for the pegs and you need 2 bushings PN 09180-08149.
I have TLR pegs and kept their feelers with NO PROBLEMS at all.
Do you feel them scrape before you run out of tire? The reason I ask is I put allen bolt's to fill in the hole's in the TL peg's and there's no feeler's on them now. The stock one's were missing from my bike when I got it. I'am getting close to the edge of the tire's sometime's and wondering if I should have the feeler's on there for a warning sign. I did not know if people were running the busa feeler's or the TL one's. I wanted to make sure whatever one's I put on there were the right length. Thank's for the input guy's.
Do they scrape, well yes if your leaned over enough, but the pegs also prevent your boot from scraping on the pavement and they pitch up if your really doing something you shouldn't on the street . They are shorter than the busa's , but at the sametime the TLR pegs put my foot about 1/2 inch lower. If you look at both, you'll notice the lowering of the peg is in it's height. They mount with the same hardware, fit the same holes and are a complete swap. I think it took me 5 min per side (I'am kinda slow ) .
I got a set of TL pegs coming. Let you guys know the results.
Looking forward to your pics mang!
So, should I use the stock busa feeler's on the TL peg's? That's all I was asking.Being shorter but lower would that make the TL peg's with the busa feeler's hit the ground at the same lean angle?
