Any thoughts on which material to go with on these? aluminum or delrin, anyone got any pros or cons to either material? such as vibration or damage to fairing paint or other?
Just installed the anodized aluminum ones and would go with Delrin if I could change my mind.
1) The aluminum ones weigh a ton. There is no good reason to put this much weight on your bike when there is a good alternative. I believe that my bike is now approximately 0.023 seconds slower in the 1/4 mile, but that could be either the extra weight or aerodynamic drag.
2) The anodized black looks kind of purple in direct sunlight.
Aside from those two points, I think the mirror extenders are absolutely excellent. MUCH better rear visibility. Either way, you will be happy with the results.
