Hello all, I have searched the forums and done as much as i can i wanted to see if anyone had any advice.
I purchased a used 2002 busa with 9,300miles 2 months ago from a close friend. i've ridden this bike before and been around it for 5 years, so i dont think my friend sold me a bike he knew was broke, but it has stopped starting on me.
the bike is getting power, but will not start, when i hit the started you hear a zzzz noise like the started motor/gear is moving but it's as if nothing else is working. you hear no engine chugg or trying to start. just the buzz of the starter moving.
1) i got off starter cover, it looks fine in there ( i think ),
2) checked all electrical i could find seems o.k.
3) checked, spark plugs and air filter
4) drained oil to see if i saw any metal in oil ( none )
im waiting for the shop to get my starter/clutch gaskets in so i can put that back on/together.
my friend said that it was getting hard to start about 6 months ago so he took it to the shop, they said he could use a new battery soon, and that his old power comander they couldn't set anymore so he got a new power comander and had it programed and he said the bike was fine and even faster then.
any suggestions on what to check/try next?
would unplugging the power comander help any? could a power commander malfunction stop the bike from running?
thanks in advance for any help
