Results 1 to 3 of 3
  1. #1
    Rookie Kat99's Avatar
    Join Date
    Jul 2009
    Location
    Toronto, Ontario, Canada
    Posts
    220
    Default 96 GSXR 1100 frame comparison to 1st Gen Busa.
    Just wondering for those experienced in building and specs etc, is there any similarity between the two??
    A guy I was talking to told me the swingarms and the forks are the same etc. Im not sure how true this is etc.
    The main reason I am asking is I am wondering if the rear shock from a first Gen busa will swap into my bike ( 96 gsxr 1100). The rear is sagging a bit now, its not too bad but definitely no two up riding.
    Penske sells a rear shock for my bike as well as the Busa. They rate both units at 7.00" in length howver the Busa has a much higher spring rate. Approximatly 100lbs more.
    I have attached a picture as reference to the shock that is mounted on my bike currently.
    Any help would be appreciated.
    Attached Images Attached Images
  2. #2
    Hayabusa Immortal
    BIG GUY's Avatar
    Join Date
    Dec 2008
    Location
    Phoenix, Az
    Posts
    4,331
    Default Re: 96 GSXR 1100 frame comparison to 1st Gen Busa.
    Someone here will chime that will be able to help you out. Are you able to compare the top and bottom mounting tabs of both of the shocks?
  3. #3
    Hayabusa Master turbobusa2000's Avatar
    Join Date
    Mar 2008
    Location
    Wisconsin
    Posts
    1,845
    Here's my GEN I busa shock that I'm selling. Looks somewhat similar. Busa shocks have a piggyback res. however.GEN I Rear Shock - Hayabusa Classifieds
Similar Threads
  1. 05+ GSXR forks on 1st Gen.s
    By JusPlaynBob in forum Engine and Performance mods
    Last Post: 03-01-2010, 02:58 PM
  2. 1st gen cans on 2nd gen Busa
    By Shaft in forum Busa Mods
    Last Post: 01-11-2010, 06:48 PM
  3. 1987 gsxr 1100
    By teamorion22 in forum General Bike Related Topics
    Last Post: 04-25-2009, 12:32 AM
  4. 1990 gsxr 1100
    By pcosho in forum General Bike Related Topics
    Last Post: 03-22-2009, 10:19 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
