Radiator fan
Morne
Can I put 2 radiator fans on my Busa 2007 and do I need a relay for this???
When driving slow in trafic it overhead and the currant fan do come on.
Thanks
Morne
South Africa
Witbank
Don't forget to swap out the stock plastic fan for the Muzzy Aluminum fan. That in itself will help cooling tremendously. The issue with the stock fan is that it absorbs the heat from the radiator and the blades become pliable and flimsy, thereby reducing cfm efficiency.
