Go Back   Hayabusa.oRg > Hayabusa Ride Faster > General Bike Related Topics
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 11-01-2009, 06:44 PM
sixpack577's Avatar
Top Gun
Group: Members
Default 200mph?
Is 200mph possible on a gen2 with stock gearing? Read that again, I didn't say stock motor, I said stock gearing. Assuming you have the extra hp obviously needed, is stock gearing capable. I have heard yes and no before. I'de like to hear from one of the few who have actually done 200...or faster. I'm still trying to get my pocket right before my non turbo no nitros 2008 will even think about that speed. At 5' 10 170lbs, K&N air filter, R-77 full system, boost by smith(turn off top end limiter, soft limiter, and fuel remapped) and workin on cf wheels and ceramic bearings, and ideal conditions, I'de like ta see 195mph on my gps. I'm then wondering how far away 200mph will be.
  #2 (permalink)
Old 11-01-2009, 06:54 PM
street racer's Avatar
Professional Pilot
Group: Donating Member
Default Re: 200mph?
Gearing commander Gearing Commander: Motorcycle Gearing Ratio Sprocket RPM Speed Chain Calculator
shows 201.4 MPH at 11,000 RPM in 6th gear with stock gearing.
______________________________________
My name is Jack and I am a Busaholic !
  #3 (permalink)
Old 11-01-2009, 06:59 PM
sixpack577's Avatar
Top Gun
Group: Members
Talking Re: 200mph?
Thanks, now I'de like some guesstamits on what my setup should do. I'de probably get more answers if I claimed I could go 250mph like this.
  #4 (permalink)
Old 11-01-2009, 07:00 PM
Seasoned Pilot
Group: Members
Default Re: 200mph?
Quote:
Yes the hayabusa 08 and 09 will do over 200 with the ceramic bearings and it makes the bike think its in 5th gear cant think of the name of the part off the top of my head it unrestricts it so it will do it. THANKS JIM
  #5 (permalink)
tclause's Avatar
Professional Pilot
Group: Members
Default Re: 200mph?
Tre is what your thinking of but is not ideal as it uses the 5th gear fuel map better of to have the ecu flashed.
A TRUE SAMURAI IS RESERVED UNTIL PROVOKED
  #6 (permalink)
Old 11-01-2009, 07:04 PM
sixpack577's Avatar
Top Gun
Group: Members
Default Re: 200mph?
Quote:
Boost by smith software will let u turn off top speed limiter, as well as up the rpm slightly by turning off the soft limiter
  #7 (permalink)
Old 11-01-2009, 07:08 PM
Seasoned Pilot
Group: Members
Default Re: 200mph?
Quote:
Yes thats it i knew it started with a t just couldnt get it out lol
  #8 (permalink)
Old 11-01-2009, 07:22 PM
sixpack577's Avatar
Top Gun
Group: Members
Default Re: 200mph?
Wonderful, since everybody and their brother that ever rode a 600 has already been 200, now I can shoot for 201!
  #9 (permalink)
Old 11-01-2009, 08:57 PM
Dozerdriver's Avatar
Top Gun
Group: Members
Default Re: 200mph?
I hear that 18/41 combo is used to get around the 200 mph mark.
  #10 (permalink)
Old 11-01-2009, 09:39 PM
B@DA$$08BUS@'s Avatar
Hayabusa Master
Default
Good info there street.
Posted via Mobile Device
  #11 (permalink)
Old 11-01-2009, 11:04 PM
dadofthree's Avatar
Seasoned Beef
Default Re: 200mph?
If you derestrict it
Robert 44,000 plus post
  #12 (permalink)
Old 11-02-2009, 12:03 AM
Fastfrog007's Avatar
Hayabusa Immortal
Group: Members
Default Re: 200mph?
Clearly you have made an error, you should have got a 600, why waste your time with a puny Busa?
They call him...Tim?
06 LE-ish, ATC 240, full Yosh,
Sweet lights
  #13 (permalink)
Old 11-02-2009, 12:19 AM
dadofthree's Avatar
Seasoned Beef
Default Re: 200mph?
Here's the thing about gearing commander. I calculated +200 on a Gen I an dropped the rear sprocket two teeth. The bike was sluggish and it did not improve the top end, because you need RWHP and torque to push the bike beyond the 180's. According to Wiki the Gen II does a little better job at that top end speed.
  #14 (permalink)
Old 11-02-2009, 01:10 AM
proud dad's Avatar
Hayabusa Immortal
Group: Members
Default Re: 200mph?
read this thread
Got-Busa? 2008 Project bike....
The Ark was built by an amateur. The Titanic, by professionals.
  #15 (permalink)
Old 11-02-2009, 07:32 AM
Commuta_Busa's Avatar
Hayabusa Immortal
Enemy Shooting Champion
Group: Members
Default Re: 200mph?
yes, with enough hp you can go over 200mph with the stock gearing.
2009 Super Streetbike's Top Speed Challenge Winner
Unlimited naturally aspirated class
  #16 (permalink)
Old 11-02-2009, 10:36 AM
Rookie
Group: Members
Default Re: 200mph?
Everything I've read, from people that HAVE done it, says it's not possible with the stock gearing. 195-196 is the best you will ever do stock with the speed restriction removed.
Brock's CT Series Exhaust (Single), BMC Race, ECU Editor, Fender Eliminator, Suzuki Touring Windshield, Soupy's 1" Riser, Suzuki Gel Seat
  #17 (permalink)
Old 11-02-2009, 10:37 AM
MET's Avatar
MET MET is offline
The Watcher
Group: Super Moderators
Default Re: 200mph?
If you have the horsepower you can get there on stock gearing. However if you have the horsepower to push gearing like 18/40 or 19/40 you will make it easier. You would need at least 280rwhp to use those gears with light winds and about a 3mile stretch. If you push your hp to 320hp you can do it in a mile. Using high octane race gas 7&a great tune.
  #18 (permalink)
Old 11-02-2009, 11:07 AM
outlawbusa's Avatar
Hayabusa Immortal
Default Re: 200mph?
Yes...with stock gearing (and stock motor for that matter) the GEN II will do 200+.
We took two Busa down before playing with too many settings...Kevin ran stock gearing on his and got his class A license on stock gearing before playing with it.
Hit rev limiter 100 feet before the mile finish line and crossed at 200 mph and some change.
We then put a 1 down on it and he ran 202 mph on stock motor
~!~There's no substitute for Horsepower~!~
200.4 mph Maxton
Part of going fast is remembering that at some point you have to slow down
  #19 (permalink)
Old 11-02-2009, 12:11 PM
Rookie
Group: Members
Default Re: 200mph?
Was this done at one of the Mile events?
  #20 (permalink)
Old 11-02-2009, 12:13 PM
outlawbusa's Avatar
Hayabusa Immortal
Default Re: 200mph?
Quote:
At Maxton mile in NC
200.4 mph Maxton
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
200mph Revolution General Bike Related Topics 34 06-10-2006 07:52 PM
200mph MET General Bike Related Topics 54 08-09-2002 12:54 AM
200mph.org.uk captain General Bike Related Topics 4 02-26-2002 05:51 PM
200mph-What does it take? OB_BarryW. General Discussion 17 06-25-2000 05:02 AM
200mph OB_gixerfreak General Discussion 2 08-15-1999 03:35 AM
(c) 1999-2010 Hayabusa Owners Group
