Go Back   Hayabusa.oRg > Hayabusa Ride Faster > General Bike Related Topics
Reply
LinkBack Thread Tools Display Modes
  #41 (permalink)
Old 11-03-2009, 04:25 PM
Got-Busa?'s Avatar
Group: Donating Member
Default Re: 200mph?
Have you touched the limiter in 6th yet or have you flashed the ECU with a raised limiter...? What psi are you running...?
______________________________________
CLICK HERE--> *Got-Busa's LSR Project bike*
"TEXAS MILE - 3/28/09: 204.468MPH"
All thanks to Brock's Performance and Johnny Cheese Tuned!
  #42 (permalink)
Old 11-03-2009, 04:38 PM
outlawbusa's Avatar
Hayabusa Master
Group: Members
Default Re: 200mph?
Quote:
I'm not on the limiter - haven't hit it yet on mine
No flash but am using the GPS mod behind the clutch to read 5th gear twice to eliminate the 6th gear limiter
PSI - high~!~
48 rear
55 front
Kevin runs higher PSI than I do, about 60 front
Guess that could expand the tires out a bit too~!~
~!~There's no substitute for Horsepower~!~
  #43 (permalink)
Old 11-03-2009, 06:02 PM
Rookie
Group: Members
Default Re: 200mph?
If you've got a private 2-mile+ stretch of road, you don't need to wait for parts. With your size, it might pull to redline in 6th as it sits. Only one way to find out....
It will, just haven't tried gps on it yet, I'm sure it's not near 200 yet. Had it all the way quite a few times while it was restricted, pulls it no problem. You can come into that straightaway easily around 100mph, it's only a slight curve. The straight itself is over 2 1/2miles, and u can see even further. Actually have a flat rear tire now, trying ta see if I can afford cf wheels before I buy new ones. Keep runnin into suprises to take my money.
  #44 (permalink)
Old 11-03-2009, 06:17 PM
Rookie
Group: Members
Default Re: 200mph?
Thanks to everyone for there input, I should pull high 190's once I have it finished. And ya never know, just might break thru, if not, Try again until I get there. I'll be sure to post once I have proof(gps screen shot) may be awhile, but I will follow up.
  #45 (permalink)
Old 11-05-2009, 05:39 AM
New Recruit
Group: Members
Default Re: 200mph?
all stock gearing but with the taller 55 tire. I went across the finish line once on the limiter at 201.4 and another time at 201.7 then when to the one down gear (42) and stock 18 front.
Sorry, I'm going to be the bad guy in this thread BUT IN MY EXPERIENCE NO, the bike won't got 200mph with stock gearing AND stock tire size.
195ish is all it will pull stock geared and stock tire based on my testing.
That gearing chart is ALL wrong based on my results...
With 18/41 205-206ish is possible and 18/42 between 200-203ish if you factor in wind, tire slip, etc...etc...
Just want to confirm you did this with stock gearing BUT 55-series tire....?
205.89 and still rising
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
200mph Revolution General Bike Related Topics 34 06-10-2006 08:52 PM
200mph MET General Bike Related Topics 54 08-09-2002 01:54 AM
200mph.org.uk captain General Bike Related Topics 4 02-26-2002 06:51 PM
200mph-What does it take? OB_BarryW. General Discussion 17 06-25-2000 06:02 AM
200mph OB_gixerfreak General Discussion 2 08-15-1999 04:35 AM
(c) 1999-2009 Hayabusa Owners Group
