| | LinkBack | Thread Tools | Display Modes |
So, as of October 30, 2009, the poll says that around 10% of riders ride in advanced group or race, while about 90% of riders corner at slower pace. We all agree that at slower speeds - street riding, track beginner group, and intermediate group - mighty 'Busa's cornering is not an issue at all. So, for 90% of the riders "Hayabusa can't corner" slogan doesn't hold water. This is very consistent with my personal feel. I am the limiting factor on how quickly I can flick the bike. OK, there is one set of pretty tight S-turns in upstate NY where I feel the bike is holding me, but I can live with that. Everyhwere else street or track, I don't have this problem. Now, keep in mind that many street riders didn't vote because they don't do track days and shy away from voting. So, the more accurate numbers increase the majority of non-superfast riders from 90% to at least 95% in my opinion. So, for most of us this is the bike that does well so many things including cornering. Case closed. Next time we argue, let's keep this in mind. Peace out. ______________________________________
Igor '01 Hayabusa HumpMod.com - the easy way |
| Quote:
Completely agree with the first paragraph. Disagree with the second one. An average guy (like me) will not get to the level where the Busa's cornering ability becomes a limiting factor. Hence, the Busa won't limit/extend the ability or the learning curve of the average guy. And if one puts the word "DOCTOR" on their pants (the butt side) - they are unbeatable. ![]() On the side note, there is a known Busa's benefit which is not mentioned often, and probably comes from that extra weight. It is rock solid in turns. I mean your are just sitting there cranked over, and thinking to yourself, all right, not much is going on, just hanging in there, waiting for the exit. ______________________________________
Igor '01 Hayabusa HumpMod.com - the easy way Last edited by IG.; 10-30-2009 at 01:47 PM. |
I agree with tuffbusa! 90% of us here dont ride pass the busa curve when cornering! That last 10% of us have another bike for that last piece. I have riden my stock busa to its ragged egde and still think its a good all round bike. I agree with you that the added weight helps make the bike more stable in and out of corners as well as its wheel base. Just have to be careful not to miss judge it.... because that weight does work the tire harder, and the cushion of error is very little! And dont forget the engine is wider too, which can hurt you if you go to far over!
My bikes: 2008 GSX1300R Blue/Black/Gold 2009 GSXR1000 Maroon/Black |
In my opinion its not allways about what the busa COULD do it about how comfortable riders feel doing so. We can all agree that lighter sportbikes are easier to corner with and it feels easier to do so with them, at least i do, So to be "just as fast" as a average rider on a sportbike you need a bit more effort and that is propably what keeps most away from the advanced group. But it can be done and like you guys allready stated 99% of the talk that the busa wouldnt be ABLE to corner is just crap, it just needs a bit more balls and effort. A whole other story is ofc. exiting the corner wich is just as important as leaning the bike in...here i personally feel most handicapped on the bus since the busa has an INSANE amount of grunt and topend power to deliver wich makes it a bit unstable for me to pull hard out of the corners. It was fun though on the track with the falcon no doubt about it. Last edited by Matso; 10-30-2009 at 03:01 PM. |
Am I the only one who works out? She can be turned in whatever and however you want her to be. Just show her who is the man (or a woman). ______________________________________
| Quote:
| Quote:
Most highsides on corner exits are due in part because the rider was in a gear to tall for the corner. I'd guess four out of five (Maybe more) bikes we pickup after a corner exit highside is one gear up from the gear they should have been in for the corner. The busa with tons of low end power and pushing an additional 100 pounds of weight compounds the chance of a highside when a taller gear than necessary is selected. ______________________________________
Get a decent set of leathers, this I am sure of All my other advice is my own haphazard experiences. |
The pipes on the 08, 09's really suck, they drag the road when u lean it over! So if u try ta push it any further, you're askin for a lowside. When they're off, u can chew off the edge of the rear tire's sidewall. The Busa corners and handles awesome.
| Put very well.
| Quote:
I do keep the bike in the upper RPM ranges.. in fact so much so that the throttle tends to be a good portion of my braking on corner entry.. I would bet I maintain no less than about 7500 rpm and usually above 8K.. I have also not had much trouble with wheel spin.. the bike has a controlled drift that is fun however.. (leaves nice blackies) |
Gee...you can spin a Busa engine AND have more control entering and exiting corners...who would have thunk that ![]() Posted via Mobile Device |
| Quote:
![]() It's the same confusion as in the other thread about the 'Busa cornering. People on different levels argue about different experiences. On the side note, I do appreciate your insight. The reason I pick a taller gear is that when I go slow, let's say while learning a new track, that same taller gear becomes "just the right" gear as my speed increases. I do agree with you 100%, that spinningthe rear at the lower torque range will make the tire to hook up too abruptly. I am aware of all that. Just not at that level, yet, if ever. I also think that most people highside because they scare themselves when the rear starts spinning, and chop the throttle. As a matter of fact, I've done visual (mental) practicing of various scenarious which are hard/dangerous to encounter or practice in real riding, including the rear wheel spin, and in this particular case I re-programmed my reflexes to never back off the throttle, but rather hold it steady. ______________________________________
I disagree with everyone.
2000 HayBus..track bike, sport touring. Full Race Tech Suspension, PC III, Corbin, Sato rearsets, Matris damper, carbon fender, Carbon Muzzy, HID lighting, billet countershaft cover, Woodcraft, Pazzos, 0-6" arm, full Autocomm electronics, Heli, Beltronics, Zumo, etc. 2005 Busa naked Superbyke..Steigler superbike handlebar conversion, Race Tech springs, Carrozzeria wheels, Braking rotors, Tobin, Oberon barend mirrors, M-4 exhaust, carbon fender, Hotbodies tail, Kellerman turnsignals, headlight assembly by CloudNine, STILL GETTING BUILT. |
And I disagree with you, everyone else, and with the guy I see in the mirror. Finally, we all disagree on something. ______________________________________
| Quote:
Get a decent set of leathers, this I am sure of All my other advice is my own haphazard experiences. Last edited by Tufbusa; 11-01-2009 at 11:08 AM. |
Raydog... I laughed so hard i almost spit coffee. Those of you that don't know Raydog.... This senior citizen KNOWS HOW to RIDE a Busa too it's limit.....I learned alot from him this summer following close on some of the tightest turns ever.. he would just drop turn that thing in at 25 down to the pegs and exit HARD and always with the revs up. Cool thing seeing him do it i got brave and was doing the same thing. Is was just shaking at the break we took right after that. Now for the flip side ... yes we are heavy.. compared to 600's and liter bikes.....BUT if the smaller bikes have expert riders we could be in trouble....On the other hand if those on smaller bikes have limited experiance....different outcome. ![]() Ps early in our ride we were going around a high speed sweeper, me right behind him and i could see his rear tire making a beautiful black smear on the road... prolly 95 mph at max lean...WooHoo ______________________________________
2001 Blue/Silver Muzzy Ti 4 into One Stock height now 1" 1/2 bar risers Brand new BT016's PCII Switchable TRE 168.7 RWHP on 87 octane |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Willow Springs "big track" track day, June 15th, for $115 | stikyy | The Hayabusa.org Trackdays | 0 | 05-28-2009 12:15 AM |
| How about "Old" Poll banning | Mr Bogus | Random Thoughts | 5 | 03-20-2008 05:59 PM |
| "hd misses the corner" | Guclu | General Bike Related Topics | 18 | 07-31-2006 07:32 PM |
| Updated version of the "Favorite Color" poll | MC MUSTANG | Polls | 10 | 08-31-2005 12:24 PM |
| "Favorite Motorcyle" poll skewed against 'Busa! | mcoyote | General Bike Related Topics | 15 | 04-11-2004 06:10 PM |
