Results 1 to 16 of 16
  1. #1
    Rookie
    Join Date
    Jun 2007
    Posts
    142
    Default How Long do you leave WAX on???
    Dumb question but how long do you guys leave wax on? I know it says when it turns grey, but I have left it on for 30 mintues and a few hours, Do wait until it is completely dry? It like powder when it comes off? Does it need to turn completely dry to work better? thanks
  2. #2
    Hayabusa Immortal
    Schism's Avatar
    Join Date
    Feb 2004
    Location
    MA
    Posts
    5,069
    Images
    Default Re: How Long do you leave WAX on???
    not a dumb question! i would not leave wax on that long because you will struggle taking it off after a while or you may possibly defeat the whole purpose and wipe it off entirely from too much force (liquid wax products). the rule of thumb is when it hazes to a white or gray, and it feels relatively dry to touch, remove it immediately.
  3. #3
    "Kowalski"
    Blazing-Saddle's Avatar
    Join Date
    Apr 2008
    Location
    Orlando, FL
    Posts
    1,770
    I leave it on until it has a hazy grey look and is relatively dry to the touch. Check the instructions on the back of the bottle/can if you're still not sure.
  4. #4
    Trouble Makers Inc.
    Mr Bogus's Avatar
    Join Date
    Dec 2006
    Posts
    2,085
    Images
    11
    if the surface is clean and polished, leaving it on for longer periods should not make it harder to wipe off... (although I remove as soon as it appears dry myself)
    It does make a difference some times as to the product you are using.. Most use "Polymer" sealants and some still use "wax" Read the container and follow their directions.. they usually know what works best for the product..
    I owned a couple detail shops in Mesa AZ and found that even in AZ, a "good" carnauba wax worked as well as most of the polymers for shine and life.. The carnauba waxes are just a bit tougher to apply (machine works best IME)..
    The polymer sealants tend to wipe on , wipe off.. The "high solvent" cleaner waxes are really nice but only last 1 or 2 wash jobs (used mostly for new car prep)..
    a couple basic DO NOTS:
    Do not wax a dirty surface (seals in crud)
    Do not wax a "hot" surface (can discolor or blemish)
    Do not wax in the sun (same as above)
    I would suggest washing your paint at least twice before using the first application of any sealant... amazing how much dirt is actually on the paint in most cases after the first wash..
  5. #5
    revolution custom paint
    Revolution's Avatar
    Join Date
    Dec 2005
    Location
    Richmond Indiana
    Posts
    7,248
    Bogus
  6. #6
    Trouble Makers Inc.
    Mr Bogus's Avatar
    Join Date
    Dec 2006
    Posts
    2,085
    Images
    11
    Hey Rev, do you use wax at all? I have come across a number of guys that do custom paint that swore off any kind of waxes over keeping the paint clean and polished... your take?
  7. #7
    Hayabusa Legend
    aussiekeeper's Avatar
    Join Date
    Nov 2007
    Location
    San Diego
    Posts
    2,137
    Clay bar once a year, then wax with NXT.
  8. #8
    Member of P.E.A.
    twotonevert's Avatar
    Join Date
    Aug 2007
    Location
    Tehachapi CA
    Posts
    25,989
    Images
    27
    I use honda polish or Plexus, remove immeadiately.
    Do you know God? http://www.lifechurch.tv/
    Its a Jeep thing, you wouldnt understand!
  9. #9
    Hayabusa Master atticdog's Avatar
    Join Date
    Dec 2002
    Location
    MA
    Posts
    1,735
    finger swipe test
    leave the wax on until you can wipe it off with a finger and it doesn't smudge
    01 Black/Silver, Pyramid DB, speedo healer, EK ZZZ, 19/42, trac 4-6, Corbin seat, 08 gsxr1K forks, radial brakes, 07 gsxr1K wheels, GT2860RS, W/A intercooled
  10. #10
    Professional Pilot Amode's Avatar
    Join Date
    Feb 2009
    Location
    San Rafael,ca
    Posts
    777
    I wax my girl friends legs it takes a month to get it off?.
  11. #11
    Professional Pilot
    Join Date
    Sep 2007
    Location
    Cary, IL
    Posts
    756
    agreed with majority consensus, wait just till it hazes and rub it out.
  12. #12
    FLUNKIE
    Join Date
    Mar 2005
    Location
    Winston Salem N.C.
    Posts
    2,986
    Quote Originally Posted by Mr Bogus View Post
    I had a paint guy tell me to wash the bike with windex or something and then if I feel the need, use a polish.
    I thought that was weird, but I guess he was shooting me straight!
    http://www.badnfluenceracing.com
    Cloud 9 Motorsports! Welcome To APE Racing , and Shinko Tires!!
  13. #13
    Seasoned Pilot oldschool's Avatar
    Join Date
    May 2009
    Location
    Daly City, CA
    Posts
    398
    I guess that depends on what product you are using. If I am using Klasse AIO, which is the only thing I use as a base now, I put it on and it can be wiped off almost immediately. I usually remove it when I get back around to where I started.
    I just finished putting on a second coat of Poorboys EX and they recommend letting it set up for 30 minutes to an hour. I usually wait the full hour.
    If I am just doing a regular OTS car wax then I let it haze and remove it but I haven't used anything like that for a long long time.
    I usually do what the manufacturer says.
    2009 White 'busa.
  14. #14
    Seasoned Beef
    dadofthree's Avatar
    Join Date
    Sep 2006
    Location
    Barnwell, SC
    Posts
    66,463
    I've waited until hazed and I've left it overnight. Never saw a problem.
  15. #15
    Hayabusa Immortal
    Strife's Avatar
    Join Date
    Sep 2006
    Location
    Tampa,florida
    Posts
    2,761
    Wait you don't let it bake in the sun then wipe off with 80grit sandpaper?
    "There are no stupid questions, but there are a LOT of inquisitive idiots"
  16. #16
    Hayabusa Legend
    head east busa's Avatar
    Join Date
    Jun 2009
    Location
    Allentown PA
    Posts
    2,159
    my suggestion read the bottle I prefer a clay bar once in a while after a good wash and then a decent polymer sealant. then maintain with a good detail spray for the time between the clay bar just for upkeep.
Similar Threads
  1. Never leave your bike alone outside.
    By Evil_keeps_me_young in forum Random Thoughts
    Last Post: 09-25-2008, 09:08 PM
  2. One Day, A Long, Long, Long Time Ago
    By Scar in forum Random Thoughts
    Last Post: 06-26-2008, 07:15 PM
  3. This is what happens when you leave
    By smonroe86 in forum Random Thoughts
    Last Post: 05-30-2007, 12:59 PM
  4. Why can't U leave a Busa alone???
    By 8Daytona8 in forum General Bike Related Topics
    Last Post: 02-04-2007, 06:19 PM
  5. Better leave your
    By Kento-Moto in forum Random Thoughts
    Last Post: 01-09-2004, 04:45 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
