notright I'm the Pugh take a wiff Donating Member Registered May 13, 2009 #1 If you have the hp and the conditions are right .With stock gearing at redline how fast are you going?
BA BUSA MotoGP Wannabe Donating Member Registered May 13, 2009 #3 You can't get to redline in 6th with a stock bike...if the conditions are right, and you have removed the speed restriction it will do 193 +/- 1mph
notright I'm the Pugh take a wiff Donating Member Registered May 13, 2009 #4 BA BUSA said: You can't get to redline in 6th with a stock bike...if the conditions are right, and you have removed the speed restriction it will do 193 +/- 1mph Click to expand... thank you ,I ment to add minus the speed restriction
mike1180 Banned May 13, 2009 #5 Here are some calculators: Stock Gearing: http://peowdebowzamow.com/yag/gearing.xls Overdrive Gearing 5th and 6th http://peowdebowzamow.com/yag/ODgearing.xls
dadofthree Seasoned Beef Donating Member Registered May 13, 2009 #6 And that's if you weigh 165 pounds or less and have a perfect tuck and a clear 2 mile straight and .....
notright I'm the Pugh take a wiff Donating Member Registered May 13, 2009 #7 mike1180 said: Here are some calculators: Stock Gearing: http://peowdebowzamow.com/yag/gearing.xls Overdrive Gearing 5th and 6th http://peowdebowzamow.com/yag/ODgearing.xls Click to expand... Thanks.
