ok, so I recently got a new fuel tank. just finished attaching it, Plugged in all the necessary attachments. Fuel line- and plugged into the snap plug the elctrical stuff.
so I turn on my bike, and You know the fuel pump makes a little different sound, which is to be expected right>
so I just turned the key off. then on, until the fuel pump sound --- was normal.
ok, so then I tried startin it, I cant get it to fire.
so I thought, mabey no gas gettin in, but I think it is- because at the end, I gave it some throttle, and the bike turned over a different speed. then back to normal when I let off the throttle. So the throttle IS doing something.
I only tried this until my battery ran out.
My FL light is blinking as well.
also before I came in for the night, I put her on the battery charger. I was thinking that I just need to turn her over alot, get the fuel going through the lines, but the fuel light, and complete lack of it firing moved me to post
please, help me out- I've got a trip planned in one day!
thanks-
--Patten
thanks-
--Patten
