Hole in the top oil cooler line
cerebusa
Anyone know where I can get another top oil cooler line?? Mine rubbed the header and started to leak. I welder it back and am riding..(could not find one in our area shops) plus they wanted over a hundred dollars for one! I would like to find one to have in case the weld does not hold although its been 2 weeks and counting. Thanks, Mike
pm me your mailing address and I can send you one. It is used off of a 07 if that is ok with you.
Are you running a Muzzy system on it? Sounds like the same issue I had when I installed the muzzy, I was lucky to fix the problem before it got into my line
Same thing happened to me with my Hindle. Thank god it happened at Wheelers, he pulled it off and welded it right there :thumbsup:
Mine did the same thing w/ my Hindle too. I replaced it & heat wrapped the spot that was close & used a metal clamp to pull it further away from the header. All good now.
