So when I bought new brake lines I also bought the clutch line. However, I do not think I am going to install it. If I am tracking it right and understanding it....the bulk of what I would be replacing is a metal tube, not a rubber hose like the brake line that I replaced. I trace the current stock line from the bars, to the frame at top of the tree about where it converts to a preformed metal tube which straddles the frame along the tank and then drops down through the middle to the clutch shifter. So I think I am going to return/sell it. Or is there is a good reason this is worth it?
