is it normal?
honestly i do not know. i dont think i can hear it on my bike. i do know that a manual cam chain tensioner is a pretty common mod for the busa. esp for drag racing. someone else that knows more will chime in soon
are you sure its not the clutch? The clutch is a coffee can full of marbles! :whistle:
No it would not be normal to her the cam chain. If it was that loose or out of adjustment you would hear it at a idle also. Check for loose bolts verst from anything up front including your headers. Then listen very careful to your cam. If it sound like the cam get it fixed right away.
My gen II is a little noisy up top. Never heard a thing on the '06 at 36K miles. I'm hoping it's just the new head.
I had a clutch bolt back out on my 02 Busa. Take the clutch cover off and check it. Even if everything looks ok, It's better to be safe than sorry. It's not fun flushing metal shavings from your engine.
