I have read a few comments on this board that seem to shy away from synthetic oils for a new bike. Can someone elaborate as to why this is a bad thing?
Synthetic oil is expensive. Switch when you want. I put standard oil in mine, but the last quart is synthetic. Giving you the same benefit as if you put an entire gallon of synthetic.
When you install synthetic rear oil with non synthetic rear oil it will turn into a paste that looks like tar. The rear will fail and we have voided many warranties due to this failure. Don't know about engine oil but I would never mix regular engine oil with synthetic engine oil.
