I purchased a chrome rear caliper bracket with pads, nuts, bolts etc - a whole set up... I have the service manual for back up but it does not address my question which is ----- can I simply remove the 36mm nut that holds the axel in place and slide the axel out far enough to slip the old bracket out and slide the new bling in and push the axel back in place? Has anyone replaced theirs. This is a 2008.
