Spent most of the day yesterday working on her, and she still looks about the same. Here are a couple of pics of the panel. I had to fabricate a few small mounts for the cameras. which took some time but don't show and I ran out of shrink tubing which kind of ended the day. From here, she'll finish up pretty quick.
If you saw my setup at the Bash last year, you've seen what I'm installing, just more of it. I'll have 2 different camera angles front and rear instead of only 1 each direction. And sound will come from remote mics instead of the internal mics on the DVR.
I got her back together. ALl the harnesses are done and connectors in place. 2 of the 3 permanent mount cameras are mounted. I didn't get a change to pull the left side fairing to punch a couple of holes in the bottom for the belly cam. I have the nose cam, tank cam, and undertail cams on along with the microphones.
