I have the racetech gold valves and new springs I am getting ready to install this weekend and I tried to do their online valving recommendation but it didn't work properly, for the compression valving it gave me a recommendation of c-nr-
so I called them at about 4:30 and the guy took my info and gave me the recommendations but he gave the the number ch34 for the compression valving, the only problem is the chart on my instruction sheet only has
c60-c69 so I dont know which shims etc... to use for my compression valving.I tried calling them back but it was almost 5 by then so I had to leave a message, and they are not open tomorrow. I was really hoping to do this this weekend.
the other #'s he gave me do correspond to the numbers on my sheet.
so If any racetech guru's can explain which shims etc... are in the ch34 compression valving stack it would be appreciated.
thanks.
Brett Collins
thanks.
Brett Collins
