I remember adding a small amount of "cox" airplane fluid to dirtbikes years ago to add some power. At least I think that was the brand. I think the stuff was like 100% octaine..... burned real hot....what if a little was added to the busa???
it was nitro ethane not methane... and will not work well in a gasoline motor.. (comes in varying concentrations (5% to 90%)
now check the % Nitro requires about twice the volume of gasoline in a motor to work.. (alcohol is the same way) but you better be up to snuff on the rest of the motor or......The jug I have contains nitromethane
it will work in a 4 stroke.. but you need double the volume of fuel over gas... the castor might even make it stink goodMight work on a two-cycle dirt bike engine. Not on a four-stroker.
--Wag--
What about putting moth balls in your tank? I heard that works too.
