What kind of tip should I use? my old one died, so I bought a new 300 series dremel to shave some of the faring on the left side of my bike, just not quite big enough to get the slider through.
so did I, but with the curve in the faring it came out just a little too small. Need to shave about 3/16" off the top of the hole. Posted via Mobile Device
I drilled a couple of holes big enough to get a sanding tube through and then went around until I got the hole the size of the slider.
The sanding tubes work real well, that plastic is soft.
