Clear clutch cover
billyerds01
Im starting the clear clutch cover mod. Can someone tell me what bit is best to use for my dremel to cut the fairing. Also how much the cost was for the clear cover. I have a solid chrome cover in place right now. Can I send the chrome one in for the clear modification? It looks like a very easy modification. If there are any tips or tricks to look for please let me know.
thepushercg is the guy to PM.. he will give you the rundown..
I have quite a few mods, but that one is bad A**. Whats the whole process....can you tell me real quick...you start by draining the fluid then what ...how did you mark the fairing to cut it?
Link to my thread.. :whistle:
https://www.hayabusa.org/forum/busa-mods/70771-clutch-cover-mod.html
And what she looks like now.. :thumbsup:
what was used to cut the fairing? Just a dremel on high? And also what did you use to finish off the cut, cause that rubber gasket thing around it looks factory! Perfect install when it looks like it came that way.
use the little cover from the clutch cover to trace out the cut..
tape over the plastic, locate the little cover and trace it out..
I used my rotozip and a bit of patience..
joseph is the man. He'll hook ya up. I used a dremel on high. just make sure you pickup a new bit and use the derby for a templete.
