longer bolts between then top triple and the handlebar triple and some washers....or they make some real nice spacers for this or you can buy a new triple clamp that will replace the stock ones and allow you to lower the front end, but they also move your handlebars forward a bit and you may have some issues with the brake/clutch resevours hitting the inner plastic under the screen
