Iowadiver
I will admit to my stupidity here... I had the tail section off and of course had to disconnect the cabel that unlocks the hump... put it all back together and forgot to re-connect the cable. Hump back on and in place=can't open it now. I figure the only way to get to it is to disassemble from the underside up... there is a bracket under the fender I can remove that should drop down the undertail section and hopefully allow access to the trunk. Does anyone have any secret tricks to avoid all this work?
