| Garage | .oRg Forums | Portal | Blogs | Arcade | Gallery | FAQ | Classifieds | Calendar | Chat | Mark Forums Read | Sponsors |
| | LinkBack | Thread Tools | Display Modes |
| Quote:
I've had mine off a few times, and haven't removed this bolt on either side. D ______________________________________ Big D |
The powerpoint was great...just need to add the last 2 push pins. there is one directly under the front right turn signal and another further back that connects the inner fairing to the outer. once you pull these the fairing will come right off.
| The first time I took mine off, that one was missing. I guess the dealer forgot to put in back in when they did the first service. It is still secure without it.
2008 Blue/black Hayabusa |
Thanks for the presentations. Baffling dis-assembly especially having removed all the pins and allen bolts only to find the fairing won't budge. Parting the fairing joint at the base and then unclipping the black plastic cowling around the base and radiator started to get things moving. The final peeling away of the fairing at the top is plain worrying until it snaps free!
| Quote:
Dobbieman's comments and photos on p 2 (Post #22) about the location of the grommets is also vital to doing this job the first time. If you do not know what a grommet is, it is a rubber sleeve that a pointed projection molded to the back of the plastic pops into. These must be pulled free. As far as unhooking the plastics all around the edges, all I can say is carefully wiggle it free. I'm sure it will get easier as we do this a number of times. The top corner by the hand grip is the biggest beotch but you will figure it out. Getting all those tabs to line up for re-installation should be interesting. |
Having put it all together again next time I remove the fairing I will do it differently. I would remove all bolts and push-pin fittings except those at the very rear underside by the 'fishtail' at the rectifier. Then I would aim to remove the front interior wheel-well side panels (photo of panels attached) by unclipping them at the sides above the leading edge of the belly pan followed by unclipping and lifting out the belly pan. The two large fairing halves would then be separated at the front and free to move except at the very rear if you unplug from the lower fairing grommets. At this point I will see if it is possible to get the Suzuki filter wrench on the filter to remove & replace it. Not sure if it will work but I can't believe dealers remove the fairing on oil changes because it takes too long, risks fairing damage and involves some patient re-assembly - this is not clever design. I was going to have a go for a bit of a challenge but the thought of going through a whole oil change for a bit of R&D - well it can wait till the next service interval. |
Note the small holes in the 3 black belly pan parts - this is where you find the push pins when you shove your head behind the wheel with a 250 watt inspection lamp!
did an oil change this weekend 4230mi on the bike thanks to the poster for pic by pic guide, it was a lifesaver but MAN, what a PITA i ended up taking the dash apart also cuz i didn't want to scratch up the fairngs when trying to remove them had to remove the oil cooler line, cuz the akro make the removal area too small. got a K&N oil filter Castrol R4 4T 5w-40 ![]() shifting is much smoother now, will prolly goto 10w-40 after spring or 4000mi ______________________________________ 2008 Blue/Blue/Gold Hayabusa, Helibars, risers, Buell peg mod, tail trimed, mirror extensions. Galfer SS brake lines, Eibach rear spring, 1" raising links, 45 tooth rear sprocket, Traxxion 1.1 front springs, Akrapovic 4:1, Throttlemeister, DDM HID & custom painted pieces by Larry. Last edited by RACER_X; 10-19-2009 at 09:54 AM. |
ALL I GOT TO SAY...is...THANKS SUZUKI!!!!! WAY TO GO......sorry i had to vent..did my first oil change yesterday.....HOLY FN......on my first gen i get it done in less than 20 min ....it took ME 1HOUR!!!!!!! ok...im done ______________________________________
Click ClickClick.....BUUUSSaaaaaaa Gone |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| REMOVING the '08 Right REMOVING the '08 Right Side | The Hayabusa | Gen II Busa Information | 9 | 06-06-2008 08:17 AM |
| Right Side Cowling | busastrom | Gen II Busa Information | 4 | 05-01-2008 08:02 AM |
| REMOVING the '08 Right Side Cowling | Warchild | Gen II Busa Information | 38 | 03-30-2008 01:18 PM |
| Right side large cowling removal help | fastball44 | Maintenance and Do-It-Yourself | 3 | 03-12-2006 07:53 PM |
