Go Back   Hayabusa.oRg > Hayabusa Ride Faster > Gen II Busa Information
Reply
LinkBack Thread Tools Display Modes
  #21 (permalink)
Old 04-13-2008, 06:51 PM
runeight's Avatar
why ask why
Group: Donating Member
Default
Quote:
Originally Posted by Kento-Moto @ Mar. 09 2008, 9:24 AM
That was great! Â*I dont know if the 08's have this problem but I leartned the hard way that we should allways place masking tape along the front seam where the lower coweling meets the front nose fairing to save the paint from scratches.
Yes sir.
And if you are running the billet gauge bezel and painted inners put tape on the bezel also.
r8
______________________________________
enforcement of immigration laws in the United States is "un-American" - Nancy Pelosi D-CA
  #22 (permalink)
Old 04-16-2008, 12:47 PM
Dobieman's Avatar
Seasoned Pilot
Group: Members
Default
I am going to add some photos of the elusive grommets for you guys to see exactly where they are and how the are positioned. This is the right side of course. Sorry I didn't take any pics of the left side when I put the exhaust on.
The first photo is the side shot of the bike with the plastic removed for reference on the close up shots.
Then the grommets are shown in no particular order.
This first one is located on top of the frame rail and you will lift up on this to pull out.
The next one is in the right corner and fits in the ram air tube. Be careful not to push this inside the ram air tube.
This one is in the middle of the frame rail.
Last this one (sorry for the small pic) is at the bottom and is the one that was originally being unbolted from the motor with the 10mm wrench. No need to unbolt just pull out
Hope this helps out a bit
  #23 (permalink)
Old 04-17-2008, 12:59 AM
Got-Busa?'s Avatar
Default
I just changed my oil today and didn't think it was bad at all. It only took me about 15-minutes to get it off. Getting the upper and lower apart was the hardest part but once you figure out how it is held together, it comes right apart. I was only surprised by how many push pines hold the fairing on. I figured Suzuki would have used more bolts like the Gen-I...
CLICK HERE--> *Got-Busa's LSR Project bike*
"TEXAS MILE - 3/28/09: 204.468MPH"
All thanks to Brock's Performance and Johnny Cheese Tuned!
  #24 (permalink)
Old 04-19-2008, 07:55 PM
sideswipe's Avatar
Rookie
Group: Members
Default
Can someone tell me the tick to PUTTING IT BACK ON??!!
  #25 (permalink)
Old 04-21-2008, 08:58 PM
Test_Eng's Avatar
Rookie
Group: Members
Default
Quote:
I started from the top right and work my way down to the lower left. Then connected the inner fender area. About a 30 minute job for the first time. Wish I saw this post first, may have made things a bit quicker.
I was reading the first post and when he mentioned the 10mm Hex head bolt. I thought I was F*#ked and I had broke something because I never took a hex head bolt out. After reading down through I saw it wasn't necessary. Fueeeeeeee!!!
  #26 (permalink)
Old 05-05-2008, 12:39 AM
New Recruit
Group: Members
Default
Thanks for this...I did my first oil change today with the help of this powerpoint.
I am not looking forward to removing those fairings again. What a pain in the butt.
There is NO when trying to get them back.
  #27 (permalink)
Old 05-11-2008, 05:11 PM
muskrat's Avatar
Rookie
Group: Members
Default
just did my first oil change and with the power point i got it done start to finish in less than an 2 hours! thanks .org
If you can't race it or take it to bed it ain't worth having.
  #28 (permalink)
Old 05-18-2008, 02:40 PM
vmaxbaby's Avatar
Rookie
Group: Members
Default
Great Powerpoint thank you for the time and effort, wish Suzuki would read these posts and somehow make the filter process a little easier. I think the Engineers that design it don't have to maintain it and that is why they don't look for better ways.
" Speed is just a matter of money... how fast can you afford to go "
http://www.flairphoto2.com
  #29 (permalink)
Old 06-02-2008, 01:24 AM
McBusa's Avatar
Group: Members
Default
Anyone done the left side? I had no problem with the right, but when I pulled the left for the SpeedoHealer install, I broke one of the plastic plugs that insert into the grommeted frame holes. Once that is broke, there ain't no real good fix. I took a 2" x 3/8 bolt, cut bolt head off, and then drilled and tapped the plastic flange. I threaded the bolt into the plastic flange so it was about 1" above the flange. The diameter of the 3/8 bolt is just about the same as the plug and with the rough threads, the bolt seems to hold the cowling ok. It's sad that the only way to fix it properly is to replace the entire left side tupperware.
If you ain't busy livin', you're busy dyin'...
66 Hodo Trail 55, 69 Yaha 180, 71 Yaha 360 Enduro
Trying to remember 76 - 06 It's a bit blurry
06 Hodo ST1300, 08 Hayabusa
  #30 (permalink)
Old 06-15-2008, 02:20 PM
KAI KAI is offline
Seasoned Pilot
Group: Members
Default
I went ahead and tried to get familiar with taking the right side off because I ordered the clutch cover mod and was going to get it prepared...I'm having trouble figuring this thing out. I took all the bolts and push pins out (I think..) but it still feels like its on there pretty tight and I really don't want to mess it up. I can't imagine cutting the fairing for this mod either.
http://img300.imageshack.us/my.php?image=christbikevb7.jpg
  #31 (permalink)
Old 06-15-2008, 05:51 PM
Heat's Avatar
New Recruit
Group: Members
Default
Very Helpful!!!!
  #32 (permalink)
Old 06-23-2008, 12:25 PM
Group: Members
Default
Thank you, this really helped. Â*
I too had a difficult time locating all the push pins. Also had a hard time making out the pictures in the owner's manual. The ones that I recall were:
2 located underneath front of the chin
1 located on chin in front of radiator (don't know that this one had to be removed, but did anyway)
1 inside fender well (small one, right side)
1 up near the steering neck
2 in front of the rear tire (rectifier area, as mentioned in the ppt)
  #33 (permalink)
Old 08-01-2008, 09:28 PM
dadofthree's Avatar
Seasoned Beef
Default
Thanx to everyone involved in the making of the power point presentation. Nice looking Busa too
Robert
  #34 (permalink)
Old 08-03-2008, 08:39 PM
05BUSABLU's Avatar
Default
very cool pp slide show, got her done in less than a hr....thanks
  #35 (permalink)
Old 08-20-2008, 11:04 AM
efiguero's Avatar
Rookie
Group: Members
Default Re: REMOVING the '08 Right Side Cowling
So where is the powerpoint being housed now? The link is no longer working.
  #36 (permalink)
Old 08-20-2008, 05:26 PM
baleibec's Avatar
Rookie
i need the link too, anyone have it saved?
  #37 (permalink)
Old 08-21-2008, 03:50 PM
Group: Members
The link to the ppt is not good anymore. Does anyone have an extra copy of this power point? I'm putting on fairing screens so I'll need to reference the ppt.Thanks
  #38 (permalink)
Old 08-21-2008, 10:09 PM
baleibec's Avatar
Rookie
its working now.
  #39 (permalink)
Old 08-23-2008, 12:16 AM
Rookie
Group: Members
Default re: REMOVING '08/'09 Right Side Cowling
Ok folks,
Getting ready to take the plastic off to put on my new exhaust. Does the 10mm bolt need to come out or not? Seems to be a difference of opinion here.
  #40 (permalink)
Old 08-23-2008, 12:18 AM
Rookie
Group: Members
never mind. Just saw the updated post and pictures.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
REMOVING the '08 Right REMOVING the '08 Right Side The Hayabusa Gen II Busa Information 9 06-06-2008 08:17 AM
Right Side Cowling busastrom Gen II Busa Information 4 05-01-2008 08:02 AM
REMOVING the '08 Right Side Cowling Warchild Gen II Busa Information 38 03-30-2008 01:18 PM
Right side large cowling removal help fastball44 Maintenance and Do-It-Yourself 3 03-12-2006 07:53 PM
(c) 1999-2009 Hayabusa Owners Group
