Results 1 to 3 of 3
  1. #1
    Join Date
    Apr 2011
    Posts
    Default Gen II standard engine in Race car
    Hi,
    I'm after an Engine MAP or advice about a reliable MAP for a standard Gen II engine in a LeMans type chassis/body work race car.
    It has a 4 into 1 ceramic coated header exiting via can through the body next to the engine. It has a large air ram above the bodywork.
    It uses standard 98 octane Australian fuel (BP Ultimate).
    The Gross weight with driver is 530kg.
    An emphasis on reliability over maximum performance is vital.
    Can the Ecu editor auto tune facility generate a suitable MAP? Is this done while driving?
    What type of switch do I need to allow for the use of the 3 standard MAP setting as on the bike- wet, sport, race?
    Are there any MAPS available to download for Australian bikes?
    Is it possible to find out about the engine numbers and the year of manufacture etc?
    Ta,
    Rusty
  2. #2
    Hayabusa Immortal
    Join Date
    Jul 2003
    Location
    Stockbridge, MI
    Posts
    3,375
    Default Re: Gen II standard engine in Race car
    You don't want an Internet map for this, you need to tune your engine in your car in the type of driving you do for best performance. You could use the ecu editors auto tune feature after collecting some data, it doesn't adjust live, collect data, then go back and it makes tuning adjustment for you.
    www.boostbysmith.com
    Boostbysmith builds many busa products including shift lights, gear indicators, gps mods for de-restriction, NOS gps mods for gear based activation, 2 step rev limiters, plug and play accessory power harnesses. ALso sell KPS heavy duty cush drive rubbers.
    sales@boostbysmith.com
  3. #3
    Join Date
    Apr 2011
    Posts
    Thanks, I'll give it a go when the ecu harness gets here.
    Any idea's about the engine number system?
    Ta,
    Rusty
Similar Threads
  1. Gen 1 engine temp, Engine Ice
    By Rooster Rider007 in forum General Bike Related Topics
    Last Post: 01-30-2011, 11:52 PM
  2. Could a gen 2 engine be droped into a gen 1 frame?
    By LeDauz in forum Engine and Performance mods
    Last Post: 12-05-2009, 08:59 PM
  3. Car with busa engine
    By Odyssey in forum General Bike Related Topics
    Last Post: 03-05-2003, 08:42 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
