Slider clutch? No clutch lever?
You do know that it is for DRAG RACE ONLY ???
Not for street use!!!
I have a Hayabusa engine in my sandrail. The smallest clutch master cylinder I could find for a buggy is way bigger than the one that came on the bike. This makes my clutch way too sensitive, there is only about 1/4 inch of pedal throw from the clutch being engaged or not. I wonder if this clutch would work in my application? If it is only for drag racing, what driving characteristics does it have? I am intrigued by not having to have a clutch lever/pedal.
this lever-less clutch shifting is stricly determined by engines RPM range. so this eliminates its usage on the streets. stalling and stuttering all over the place:beerchug:
oh yea forgot to mention is almost 2 grand. to me not worth it a bit unless ur deep into dragging.
i would call mtc and check with them and see what they think about it being used in your sand rail.:thumbsup: but if you do use you will have to tow the buggy back to the pits:thumbsup:
