Results 1 to 9 of 9
Thread: Engine Rebuild
  1. #1
    Rookie WhiteBusa24's Avatar
    Join Date
    Nov 2007
    Location
    TX
    Posts
    204
    Default Engine Rebuild
    Hey Guys,
    I have a '02 LE with 32,870 on the clock. My buddy that I got it from didnt really take care of it. He did the oil changes in it, and replaced the clutch but that's about it I believe. 2nd gear pops @ 4k also. So...when I fix the tranny I figure I could give the engine a little cleaning and overhaul. What do I need to do. I do not need a 1397, stock is good for me. Just want everything to be clean and new. So...what would I need to buy to get back to like new shape?
    Thanks
    Ram
  2. #2
    Join Date
    Nov 2007
    Location
    TX
    Posts
    204
    Default Re: Engine Rebuild
    Here is a night pic
    Attached Images Attached Images
  3. #3
    Seasoned Beef
    dadofthree's Avatar
    Join Date
    Sep 2006
    Location
    Barnwell, SC
    Posts
    66,782
    You might think high compression pistons, and new cams. Suppose to deliver close to 200 ponies with the stock look.
  4. #4
    Join Date
    Nov 2007
    Location
    TX
    Posts
    204
    What else would i need with pistons and cams?
  5. #5
    Seasoned Beef
    dadofthree's Avatar
    Join Date
    Sep 2006
    Location
    Barnwell, SC
    Posts
    66,782
    Quote Originally Posted by WhiteBusa24 View Post
    As far as I know that's it.
  6. #6
    Hayabusa Immortal
    Commuta_Busa's Avatar
    Join Date
    Mar 2003
    Location
    Carteret, NJ
    Posts
    7,671
    Images
    107
    since you're looking to stay at a stock level and are really focused on reliability/durability I would just make sure the cylinder walls look good, pistons crowns, cams, buckets, springs. Since you're going to split the case to get to the trans you may consider checking the bearings and replacing them while your that deep into the engine. Check all the journels as well. If everything checks out then all you'll need, aside from the trans work, is new bearings, piston rings.
    2009 Super Streetbike's Top Speed Challenge Winner
    Unlimited naturally aspirated class
  7. #7
    Join Date
    Nov 2007
    Location
    TX
    Posts
    204
    Cool...any idea on cost for all not including tranny?
  8. #8
    Hayabusa Immortal
    Join Date
    Mar 2003
    Location
    Carteret, NJ
    Posts
    7,671
    Images
    107
    Here's my standard answer to "how much:..., "it depends".
    Bearings aren't cheap, rings aren't so bad. Check to see the condition of everything first. If you need cams and vlalve springs it may be worth sending your head to someone to be refreshed all in all.
    If your cylnder walls look like crap then it might make sense to have it bored and that may mean bigger pistons and rings.
  9. #9
    Join Date
    Nov 2007
    Location
    TX
    Posts
    204
    sounds good
Similar Threads
  1. Busa Engine Rebuild Videos
    By mike1180 in forum Maintenance and Do-It-Yourself
    Last Post: 09-22-2008, 03:06 AM
  2. rebuild or replace engine?
    By 99'busa in forum Engine and Performance mods
    Last Post: 12-29-2007, 10:57 AM
  3. Going to do the engine rebuild myself
    By Don Hardcastle in forum Engine and Performance mods
    Last Post: 08-06-2007, 10:44 AM
  4. Engine upgrades while doing tranny rebuild
    By SKILLZ in forum Engine and Performance mods
    Last Post: 04-16-2007, 08:07 PM
  5. Things for my engine rebuild ?
    By C_Henry in forum Engine and Performance mods
    Last Post: 02-12-2006, 09:24 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
