SKILLZ
Ok guys, I finally got around to dropping my motor yesterday and I am going to do the tranny rebuild(2nd gear@3500 mi). I am looking for ideas on upgrades while it is down. I know im going to raise the compression and do the ex. cam and port the head. Should I go with the short velocity stacks on all four? I am planning on making around 200 the rear. I am curious about the clutch? Do I need heavier springs, or different clutches? I should have the motor torn down this evening and I need to know what to do on the trans. I want to have the new pieces back cut, and I was wondering if anyone has a picture of a stock vs. a backcut gear?? If so can you post? If you guys have any other ideas I will be glad to hear them. Thanks!
list of mods im going to do:
pair valve removal
port head
raise compression
exhaust cam changed to intake cam
full exhaust
muzzy fan
pair valve removal
port head
raise compression
full exhaust
muzzy fan
