Go Back   Hayabusa.oRg > Modifications > Engine and Performance mods
Reply
LinkBack (3) Thread Tools Display Modes
  #1 (permalink)
Old 08-12-2004, 09:26 AM
jamesnismo's Avatar
New Recruit
Group: Members
Default
ok guys i need your help. just installed full akra evo exhaust and pc3r. now i want to do the airbox mod. i believe there are two different mods for it right? the "small airbox mod" and the normal, or whatever you want to call it. which to do? and anybody have a good how to with pics? the last thing i want to do is have to replace an airbox cause i got too dremel-happy. * *thank james
<!--EDIT|jamesnismo
Reason for Edit: None given...|1092317270 -->
______________________________________
&quot;speed through superior riding&quot;
  #2 (permalink)
Old 08-12-2004, 10:59 AM
jusmoov's Avatar
Seasoned Pilot
Group: Members
Default
I got the BDE full sytem on my bike and it came with instructions for an airbox mod that was real easy to do, only problem for you is you cant just do a mod without having a map thats going to compensate for it, if your gonna do it just make sure you get a custom map, or see if the akro comes with a map 4 the pipe with airbox mod. Next, What I did was remove gas tank, take out the air filter, then airbox, You will see a flapper with a triangular shape around it with one small hole on the inside, drill holes next to each other all around the inside of the tiangle the same size as the existing hole, then take a saw or something and cut out that piece. Better yet go to Brocks site and look up instrutions on how to do this he has good picts there. ( boy that was a waste of typing)!!
2004 Black/purple Busa * * 2003 Yellow TL 1000R
BDE Titianium Full Sys.
PC IIIr
Air Box Mod
Removed Pair Valve
Lowered
16t front 41t rear sprockets
ART carbon tank guard
LP carbon frame sliders
DB windshild
  #3 (permalink)
Old 08-14-2004, 03:54 AM
Group: Donating Member
Default
If you do Brock's mod, it should look like this when done...
What you think of me is none of my business.
  #4 (permalink)
Old 08-14-2004, 05:58 PM
The one who started it all
Default
Quote:
Originally Posted by [b
Quote[/b] (WarBaby @ Aug. 14 2004,04:54)]If you do Brock's mod, it should look like this when done...
Warbaby, just wondering do you run an air filter or is the element cut away. Also what do you do to stop that annoying acuator from making noise between 3,500 and 4,00 rpm.
2003 SonicSilver/FlintGrey sold
www.CarpenterRacing.com
2005 LE with a twist..
  #5 (permalink)
Old 08-15-2004, 03:06 AM
Default
Both factory and aftermarket air filters work fine with the air box mod. Did you do a PAIR removal mod?
  #6 (permalink)
Old 08-15-2004, 12:44 PM
Default
Im runnin' my stock filter I think it flows better than an oil soaked K&N. My question was do you or have you ever heard of cutting the element away and goin' with no filter at all. When I had my top end done It was strongly suggested that I go with no filter at all and this was common for developed N/A Busas'. I also called Lee's performance and they said the same. I was just wondering what you had set-up. Also about the acuator that normally would control the flapper how did you disable that. Mine makes noise on a cold motor right around 3,500 to 4,000 rpms.
  #7 (permalink)
Old 08-15-2004, 01:08 PM
Seasoned Pilot
Group: Members
Default
have you LOOKED at the bugs that get in your filter??
04 black and blue
yosh cams , brocks pipe ,pc3
sml box mod , throttlemiester,
buell pegs, hugger
silverstars , 17/43s , hugger , muzzy fan
DID chain , signal minder
DaveOs extended ecm , brembo master cyl,
pazzo levers , ss b lines , tobin seat,
billet vel stacks , more to come im sure
  #8 (permalink)
Old 08-15-2004, 01:34 PM
Default
I know what you're sayin', trust me. It just seems that alot of people are runnin' with no filters. I wouldn't worry about the bugs as much as the pebbles and sand.
  #9 (permalink)
Old 08-16-2004, 03:55 AM
Default
Sorry I overlooked your main points.
Im runnin' my stock filter I think it flows better than an oil soaked K&N.[/quote] Me too...for similar reasons.
My question was do you or have you ever heard of cutting the element away and goin' with no filter at all.[/quote] Yes, but I prefer Brock's solution for less flow disturbance. BDE Air Box Lid
Also about the acuator that normally would control the flapper how did you disable that. Mine makes noise on a cold motor right around 3,500 to 4,000 rpms.[/quote]Interesting! It sounds like you reconnected the actuator diaphragm hose. You might try plugging it off.
BDE Air Box Mod
Air Box Mod
Also, if your Busa is a track-only bike, I understand not using a filter for THAT purpose, but... as you may know, extended street use without a filter WILL result in premature engine wear of cylinders, pistons, rings, and probably valve seats.
  #10 (permalink)
Old 08-16-2004, 11:24 PM
Default
Thanks man!!
  #11 (permalink)
Old 08-18-2004, 10:14 PM
Smoke_Dog's Avatar
Hayabusa Immortal
Location: Stuck in Valdosta Ga, but a HICKORY N.C. NATIVE
Group: Members
Unhappy
Hey Guy's,
What is the difference betwenn K&N and BDE?
BUSA-OLOGIST
Pair Mod, K&N Filter, Air Box Mod, PC111 USB, GIpro with ATRE, Mirror Mod, Numberous Chrome add ons!
  #12 (permalink)
Old 12-04-2004, 02:45 AM
loboboy's Avatar
Default
In all honesty who can tell the difference in 2-4 HP? I don't want to loose any low end torque just for 2-4 HP. If it made 10 HP difference then it would be worth it but honestly is it worth the loss of the low end torque? Torque is acceleration, HP doesn't do you that much good at low speeds only top end. I personally would rather have the low end, it has enough top end as it is. Just my .02.
They call me TATER SALAD!!!!!!!!!
  #13 (permalink)
Old 12-04-2004, 04:32 AM
justintime2's Avatar
&quot;What's your story?&quot;
Default
That Fast Sjonny's website has alot of info on the Busa!
Click Warbaby's airbox mod link.
JT2!
03' BLK/GRY
Carbon-mirrors,grips,levers
Bluegauges.com
TopGun/Hugger
EK530ZVX
  #14 (permalink)
Old 12-11-2004, 03:00 PM
New Recruit
Group: Members
Default
The vacuum actuator can be removed from the bottom of the airbox and discarded. Use the plastic flapper and make a cap to cover the hole where the actuator used to be and epoxy or plastic weld it airtight. Then plug the hose. The stock filter is a good idea to use.
03 Ann. Edition, Yosh TRS carbon,PC3usb,pair valve,Marvic Penta II magnesium wheels,Pirelli Diablos, TG undertail,Roca hugger,ZG db screen,ART carbon tank pad,pro bolt fairing bolt,carbon look mirrors,levers,rumble import carbon front lenses,Muzzy fan,Gilles rearsets,carbon hugger,carbon inners.
  #15 (permalink)
Old 02-04-2005, 11:47 AM
Hayabusa Master Jedi
Default
... please throw some light on this for me. What is the "Airbox mod"... and why would one want to modify their Airbox
Sorry about the stupid question!
"Fear is the path to the Dark side, fear leads to anger, anger leads to hate, hate leads to suffering." - MASTER YODA
  #16 (permalink)
Old 02-04-2005, 12:02 PM
frisbee's Avatar
GODSPEED RACING
Default
Its all about getting more air to the engine, more efficiently. You don't need to do it unless you've done other mods ie.. exhast ect... . You can do it to a stock motor but I don't know if your motor would need a re-mapping .
second place is just a name for the first loser
3-9" 600 arm, #36 dry NOS, 208HP @ 137FT LBs Â*,BMC Filter, Airbox Mod, Adjustable Rear Links, 1" Reapers Risers, Yellow ZG DB, HID Low beam, Icemann Yellow Hi beam, Speedhut gauges, Carbon Fiber Everywhere, pusher cover
  #17 (permalink)
Old 02-04-2005, 10:10 PM
Default
If you have done the exhaust do the air box, there is a difference you will notice.
2004 Black/ Purple died July 24, 2007
Now 2007 BMW K1200RS
  #18 (permalink)
Old 02-05-2005, 08:18 AM
Default
oh...ok frisbee.
manatrader, I have ordered a couple of yoshimura zyclone carbon fiber bolt-on's. Also changing to K&N filter... and adding a PCIII.Would I benefit from the airbox mod
I mean will I have a noticable difference in the performance?!
  #19 (permalink)
Old 02-10-2005, 01:36 PM
New Recruit
Group: Members
Default
I have done the small airbox mod and I am not to happy. I have a lot more monoxide being produced and gas mileage is terrible now. Unless your bike is drag only, I wouldn't do it. I am currently looking for another airbox to buy and put on my bike.
Brian Norwood
Too Fast for the FAST
  #20 (permalink)
Old 02-10-2005, 01:38 PM
New Recruit
Group: Members
Default
Brian Norwood
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.hayabusa.org/forum/engine-performance-mods/25877-airbox-mods.html
Posted By For Type Date
hayabusa air box mod whats the deal - Pashnit Motorcycle Forum This thread Refback 01-27-2009 03:13 PM
hayabusa air box mod whats the deal - Pashnit Motorcycle Forum This thread Refback 01-18-2009 12:19 PM
hayabusa air box mod whats the deal - Pashnit Motorcycle Forum This thread Refback 01-18-2009 09:53 AM
(c) 1999-2009 Hayabusa Owners Group
